Trying to Set/Verify Squish
MetalManMaxx
New Member
Hey guys, would anyone be able to give me some advice on whether I’m reading my Squish correctly? I set the zero using the dial indicator with the piston pushed all the way up to top dead center in the cylinder head (crashed against the top of the head). I used the wrist pin and needle bearing to help me stabilize the piston in the head on the reading in the pic.
Am I supposed to be reading backwards from my zero to the long needle which would make my squish .022-.024? It makes sense to me that I would only count the lines in between the 0 and the long needle but most of the videos on this are like 14 years old and you can’t see 💩 in them lol.
thanks for the help and for anyone curious this is a ESP G340rc stroker long block kit I’m trying to build.
I did want to ask as well if I am correct with the reading can I possibly go down to a .03 or .005 gasket? Or would the gains not be worth the risk? Thanks again.
On a dial indicator like that each small has is .001. So what you are reading is 22 dashes or .022".
For a plunger style like that clockwise movement is high, counter clockwise is low. So, from the piston smashed against the top at zero, and now the crank built and the head on the piston at TDC you've got .022 clearance, your reading. If you add a .005 shim you'll be at .027. If I remember the stock g320 is about .039
Thank you, I really wasn’t sure and didn’t want to screw it up. With the shim I was thinking I’d swap the stock shim to get closer to .15 but I’ve been told that might mess with the porting and cause top end speed issues. Do you guys agree on just leaving the stock shim as well?
How its done in the chainsaw porting world is to use Solder. Its placed between the piston crown and combustion chamber out at the edges. On the sides where the wrist pin slides in the piston. Roll the motor over a few time till you no longet can feel the resistance of the solder being squashed. Then you measure it with calipers. That's the squish clearance at the squish band area.
This is the easiest way by far to do this.
It can also be done with a dial indicator on a threaded insert in the plug hole.
Run the piston all the way up to TDC and zero it.
Remove the cylinder from the case being careful not to disturb the indicator.
Remove the piston from the rod and install it back in the cylinder.
Gently pust it all the way up into the top of the cylinder until it bottoms out in the top of the cylinder.
Now read the indicator.
The difference from zero when it was installed on the case to the reading when it is removed and the piston pushed to the top is what you have for squish.
...........and yes, the longer rod and base gasket thickness does affect port timing so keep that in mind.
