DemonRC1
Well last night I prepared my XBE for it's first run. Before I ever even plugged the batteries in I figures I was going to do some mods. First, I needed to figure out if I wanted to stick with FG hubs and run the stock tires and then later switch to better FG style tires like the buggy tires from Nutech. I figured I'd just run my bowties untill I pick those up. So, if you want to run Baja tires you have two choices:
1) Get some Ramtech adapters with 7075RC hubs. You HAVE to get the 7075 hubs if your running adapters. The 19mm hubs bearings will blow out in a few runs due to the extended length hubs putting more pressure on the bearings.
2) Switch over to TT hubs and axles. This has been something I've been wanting to do for some time. I know a few have done this already but there are a few key points not mentioned. The only reason I haven't done it is that I didn't want to lose my swaybars. Well, it turns out you can still use the sway bars. I think this is the route I want to take untill Obeast44 does a review on the Nutech wheels
Here's a few key things I ran into when making the switch:
All in all I'm happy with the switch. When I ran today I could just relax and have fun without worrying about whether or not my adapter setscrews are going to come lose, if I'm gonna kill my foams, etc, etc.
- Because the TT arm does not have the raised lower shock mount the end of the shock sits inside the TT arm. This allows you to use the XB rear shocks on the front for more suspension travel. I noticed that the XB front shocks are too short and do not allow the arms to droop. You do need the arm to lower by some degree to maintain traction when traveling over dips and/or washer boards. The arm has to have some downtravel so that the wheel can stay in contact with the ground. Killing downtravel by having short shocks is like having 1/2 suspension. The XB rears on the front are a big plus.
- You can keep the swaybars by drilling a hole for a screw. Refer to the picture for the location. One thing you have to do is pull the swaybar out of the joint maybe 3-4mm.
- I have to doublecheck the V3 arms once they come in for droop control screw locations but I'm pretty darn sure that the V3 arms have them in the same spot from looking at some pictures another member sent me.
- Since the TT/MT axles are identical to the Baja axles we can run all the aftermarket hubs offered to the HPI guys. I want to get my extended Vertigo axles I used to have on my TT. They were really nice. Eventually I'm gonna run the GRP's like below:
- The switch over is really easy. All you have to do is add a few washers for the rear hubs and they go right on just like the stock hubs. For the front, you just need to drill two holes in the back of the arm so mount the swaybars. There is one thing about the rear hubs that I need to mention. The XT/XB/XBE uses a 5mm hinge pin to hold the hub. The TT hub is made for a 6mm hinge pin. So there is a little play in there. I ended up drilling out my hubs and installed bushings to take up the play. It's not necessary since it's not that noticable.
