Yep Deluge runs those with temper treated cups with no issue.rampagemt said:There's a member on the forum that's running them on his mt
No problem. Good luck.dansmg said:Thanks for the info. looks like that will fix my problem.
Direct fit on the mt correct ? What drives axles fit with these bones ?RCDAD said:These are more HD http://www.largescalerc.com/mcdreardriveshaftdogboneevo2andevo3.aspx and they will fit.
Yes those fit. You still use the Redcat cups. If you sleeve your cups they become much stronger.MNRampage said:Direct fit on the mt correct ? What drives axles fit with these bones ?
