Phill2
Maybe you have a better mesh now?Dongskie said:hehehe... just wondering coz it didn't have it before the gearplate upgradeanyways
My plastic gears lasted exactly 4 minutes so you're doing well.
The one other difference I've found is the air filter is the 2 stage Baja oneRampageHopUps said:I thought the Bajer was based on a longer MT Chassis? That is what NitroRCX sells it as.
Shorter W/B?Phill said:The one other difference I've found is the air filter is the 2 stage Baja oneThere is a shorter wheelbase HSP also called a Bajer which is also 4wd but available in 2wd too
Maybe that's the one you re thinking of
It comes as 26cc whereas the longer one is 30.5
I swappedout my 30.5 for a 29cc 4 bolt Zenoah
This is the shorter oneDongskie said:Shorter W/B?Maybe they copied HPI's wheelbase length...
How did you properly mesh the gears when you have no adjustments to work with..as for the noise you hear it ma be from the lay shaft is too tight.Dongskie said:Hi guys,Recently I got and installed my new Aluminum gear plate and it fits well with no trimiming or anything and it looks great too!
Anyway, after I have completed installing the gears and meshing them properly I got a new sound out of it, a whining sound.
I still have the stock plastic gears so I suspect that is is coming from the bevel and pinion form shaft C, but I am pretty sure I meshed them properly
here is a short clip of the whining sound:
Most likely the set screws on the gear square has come loosemellow1978 said:i just did the upgrade couple days ago mine makes the same sound. but i have a problem i went over couple of bumps and my clutch aint working how long does the shoes last i ran a gallon of fuel in it
