Upgrade steeringservo
Relic-1
Build Thread Contributor
Spoklahoma Washington
My plan be was to upgrade my steering servo on my vekta , I don't want to go to double steering just a better servo , if that is even a option with thetrepodore tires I put on , I expected the need for this but not the double steering , any vekta owners know a good upgrade , besides the $600 devorced causing method ?
Well before you go spend a lot more check out jx 2060 50 dollars check the specs I have one on my five t wth maybe 5 tanks held up so far .
I geuss I'll go with the two craken server set up ,balanced system seems to be a popular choice and financially possible ,then it's the steering nuckles , I'm wondering the importance of metal upgrades a arms , I'm not out to win any self comforting awards or plaques or badges I just don't think there nessasary are they that much of a change ?
Careful with dual servos, if they are not perfectly sinks they will fight each other and burn out.
As far as aluminum arms, there not needed and much more expensive to replace than stock ones. You want a breaking point somewhere, arms are cheap and good to break instead of a chassis or something more expensive
I been running dual Kraken servos for a while now with the Maxxis tires.
The setup of the linkage is very important. Play with both sets is a good thing. When I first set then up they got tight at full travel causeing my slave servo to run hotter, I found the sweet spot in the adjustment. At this point in time all my servo heat issues are gone and the linkage has good play in both directions at full travel and continues to turn on a dime.
Good Luck with your setup.
Best Regards,
William E. Burrows Jr.
Best Regards,
This right here
I cannot give an opinion on the Full Force setup, I went simple using the stock Kraken servo and their dual steering servo kit.
So far its works.
