sperera
well i pulled apart the FG last night, removed the pipe and rear roll cage so that I can removed the cowl and give it a clean. Came apart find but I made a BIG mistake putting it back together.
One of the bolts on the pipe where it bolts up front didnt go in smoothly. It would get about an inch in and then become very tight. No matter what angle I tried it would go in an inch and get real tough to turn.
I thought if I keep turning it no matter how tight it is it should create its own threads, this worked until I got about half an inch from the flange when the bolt stripped (allen key type).
Can the bolt hole in the front be re-tapped or do I need to replace the head? I think I can get the bolt out slowly using multigrips but its going to take ages.
Please help. :helpsmilie:
