Vekta LSE build
Thanks to DDM and RCMAX for all your help!!!!
DDM DOMINATOR FD770
FFORCE DUAL SERVO MOUNTS KV137v1
TURTLE RACING STEERING LINK KV120
TURTLE RACING THROTTLE MOUNTS KV124
VERTIGO TRAILING ARM LINKS KV129
FFORCE MUD GUARD KV138BLK
DGI 1" EXTENDERS KV165
VERTIGO FRONT CHASSIS BRACE KV132
VERTIGO REAR UPPER QUICK RELEASE KV175
KV193PO & KV194PO SERVO SAVER RT AND LFT SIDE
VEKTA BILLET SPINDLE SET KV6101
VEKTA BILLET SPINDLE CARRIER KV6102
VEKTA RR SHOCK STOP 8mm KV6624
VEKTA BILLET RR UPP HEIM KV6103
VEKTA BILLET RR LOWER LINK MT KV6104
VEKTA BILLET FRT UPPER A ARM KV 6105
VEKTA BILLET FRT LWER A ARM KV6106
VEKTA BILLET FRT DIFF HOUSING KV6107
VEKTA BILLET UPPER HEIM JT KV6108
VEKTA TREPADOR TIRE SET KV6109
VEKTA TREPADOR FOAM SET KV6110
VEKTA T90 TRANSMISSION KV6120
VEKTA BILLET VERTICLE CHASSIS PLATE LEFT KV6602
VEKTA BILLET VERITCLE CHASSINS PLATE RT KV6603
VEKTA BILLET LIGHTENED SHOCK TWR KV6608
VEKTA BILLET RR UPP LINK MOUNT KV6613
VEKTA BILLET FRT UPPER BRACE KV6617
SAVOX SV-0236-MG SERVO X 3 HT240
ESP 34CC,STROKER FULLY PORTED BB133C
RCMAX BILLET RR AXLE HOUSING
JS PERFORMANCE FRT SHOCK STOP KV156
IRP VEKTA RR SWAY BAR MOUNT KV115
IRP VEKTA.5 STG TIE RODS KV116
IRP VEKTA.5 SERVO LINK KV117
CHUNG YANG FAN COVER EG411 TO MOUNT T90
CHUNG YANG CLUTCH PLATE GT244 LOW PROFILE FOR NEW ZENOAH 34CC ESP PORTED
CHUNG YANG CLUTCH PLATE BOLT GT249
RADIO LINK R6F RECEIVER
RADIO LINK RC6GS TRANSMITTER
KILLER RC 5200mah lipo rcevier battery
beast:oops::p(y)
DDM DOMINATOR FD770
?All that investment and you get a RadioLink? I don't know much about it but, why not a Futaba or Sanwa?
KV7703 +DDM DOMINATOR FD770 Vekta.5 LSE Pro Kit 1250
FFORCE DUAL SERVO MOUNTS KV137v1 90
TURTLE RACING STEERING LINK KV120 39
TURTLE RACING THROTTLE MOUNTS KV124 25
VERTIGO TRAILING ARM LINKS KV129 50
FFORCE MUD GUARD KV138BLK 45
DGI 1" EXTENDERS KV165 30
VERTIGO FRONT CHASSIS BRACE KV132 50
VERTIGO REAR UPPER QUICK RELEASE KV175 17
KV193PO & KV194PO SERVO SAVER RT AND LFT SIDE 140
VEKTA BILLET SPINDLE SET KV6101 100
VEKTA BILLET SPINDLE CARRIER KV6102 105
VEKTA BILLET RR UPP HEIM KV6103 120
VEKTA BILLET RR LOWER LINK MT KV6104 105
VEKTA BILLET FRT UPPER A ARM KV6105 116
VEKTA BILLET FRT LWER A ARM KV6106 155
VEKTA BILLET FRT DIFF HOUSING KV6107 140
VEKTA BILLET UPPER HEIM JT KV6108 48
VEKTA TREPADOR TIRE SET KV6109 48
VEKTA TREPADOR FOAM SET KV6110 9
VEKTA T90 TRANSMISSION KV6120 250
VEKTA BILLET VERTICLE CHASSIS PLATE LEFT KV6602 75
VEKTA BILLET VERITCLE CHASSINS PLATE RT KV6603 75
VEKTA BILLET LIGHTENED SHOCK TWR KV6608 65
VEKTA BILLET RR UPP LINK MOUNT KV6613 40
VEKTA BILLET FRT UPPER BRACE KV6617 63
VEKTA RR SHOCK STOP 8mm KV6624 35
SAVOX SV-0236-MG SERVO X 3 HT240 360
ESP 34CC,STROKER FULLY PORTED BB133C 524
RCMAX BILLET RR AXLE HOUSING 45
JS PERFORMANCE FRT SHOCK STOP KV156 45
IRP VEKTA RR SWAY BAR MOUNT KV115 80
IRP VEKTA.5 STG TIE RODS KV116 79
IRP VEKTA.5 SERVO LINK KV117 32
CHUNG YANG FAN COVER EG411 TO MOUNT T90 15
CHUNG YANG CLUTCH PLATE GT244 LOW PROFILE FOR NEW ZENOAH 34CC ESP PORTED 5
CHUNG YANG CLUTCH PLATE BOLT GT249 4
RADIO LINK R6F RECEIVER 50
RADIO LINK RC6GS TRANSMITTER 30
KILLER RC 5200mah lipo rcevier battery 50
Vekta.5 front sway bar kit KV2209 39.99
Vekta.5 Rear Spoiler Light Kit TR650 28
Vekta.5 Rear Spare Tire Rack Bracket Kit TR649 45
Killer RC IRIS LED Double Red and Yellow 12
Vekta.5 Maxxis Trepador Tire Set for spare KV6109 48
Trton Wheels with beadlocks TT324 45
Bite Screws nc160 8
Killer RC Super Bee Kill Switch Fail Safe 60
4889.99
That's too much aluminum for my taste, unless its a shelf queen. You run into something without much give with a aluminium front end, you're going to have a lot of billet paper weights and more money to put back into fixing what ever broke, but also what also broke from the direct result of those shiny objects transferring that energy that nylon or some hard plastic would have absorbed into something not cheap to fix. IMHO.
You know that statement:
"$hit happens".
There is no guarantee something wont/will happen,no matter how cautious you are.
So I'd say a long as you know that ,procede as you like.
The guys are just looking out for you,so you might not have to get a 3rd mortgage.?
A big clear field probably safer then a small parking lot but unexpected things happen.
I have some back up aluminum pieces in case of that day of doom.
Yep living on the edge.??
