- Reaction score
- 27,691
So I got 1 1/2 - 2 gallons of e85 and gas, how do I dispose of it?? I don't want the cans to explode from the cold and I have nothing to burn it in
Yeah but I don't intend to reuse that exact fuel. I need rid of itKeep cans sealed and out of direct sunlight. The fuel will last until you are ready to use it.
And get evicted ?Could always start a bonfire with it ???
YeahDo you have 2 stroke oil mixed in it ?
Ok. I'll see about that. I only mixed that much was cuase one was e85 l, one was gasoline (to purge e85), and I foolishly thought my Engine would run after a couple trys. Which was not the case lolDon't add it to your dads car. You are going to need to find an alternative container for the fuel to get rid of it. Auto parts stores are required to take used oil , antifreeze and hopefully fuel. You are going to need to call around and see who will take it ( gas stasions , auto parts stores) . First mastake never mix more fuel than you are going to use. Good luck
It's a BMW and will probably freak the fek out cuz it has sensors everywhere ?The two stroke oil wont hurt anything in the car, it will be so diluted by the time that 3 gallons mixed with the other 10 in the tank you'll be something like 200 to 1
Well I forgot ?Thought you had an Altima
