teamchrome
Amsoil Dominator and Coleman.
What is Coleman® Fuel?
Coleman® Fuel is basically petroleum naphtha with a bit of rust inhibitor. It has an octane rating of 50 to 55 and none of the additives found in gasoline. It has a lighter molecular weight than gasoline, kerosene and diesel fuel and cannot be used as a substitute for any of those fuels. The flammability of Coleman® Fuel is comparable to gasoline but it cannot be used in gasoline engines. It will burn out the valves.
An un-opened container of Coleman Fuel stored in a dry area with no rapid extreme changes in temperature will remain viable for five to seven years. An opened container stored in the same area will remain viable for up to two years though will be at its best if used within a year.
Do not attempt to use Coleman Fuel in an internal combustion engine. Coleman Fuel is very low octane with none of the additives needed for engine use. It burns very hot and will burn the valves out of an engine.
For disposal methods of Coleman Fuel that may no longer be viable, please contact the Hazardous Material department of your local Fire Department.
Thank you,
Sally
Coleman Consumer Service
1-800-835-3278
