990 carb is the best you can getWanting more performance out of my blackout
NopeAre they hard to tune
It's well and truly chucked.
thats funny!It's well and truly chucked
The 990 carb is by far the easiest to tune and simple to start but you cant just go yanking on the pull start and think it will fire up. There is a reason so many high end motor builders recommend this carb. Before yanking on it prime the bulb, give it 3-4 slow pulls on the rope to prime the engine, find a compression stroke then give it a solid yank it should definitely fire if the tune is close to recommended settings.
