You can always buy a new top end 1st. before laying down some serious cash for a comp. engine.badboy2 said:ok i guess a better engine is where i need to save up..
Ti is the worst for that stuff; too brittle. Any good quality baja front turnbuckles will be a direct fit. My brother just picked up these and they are beefy to say the least:mooman007uk said:unlike my python titanium front turnbuckle that I snapped within 10mins of their maiden run![]()
Thanks for the correction on final cc , My stroker screams , revs as fast and as much RPM as my GP290 , I'll put my Custom Fabrications ported up on a dyno against OBR , DDM , or ESP . I have ran with some of the ONB and they got no pull out from my motor.biggiecamp said:A 28.5cc mill is a stock crank with the GP290 36mm piston and head. The 35mm bore is used in the 29cc motor. I like the 28.5 because it maintains the stock stroke, so there isn't as big of a fall off in RPMs. Unless OBR ported it, then it'll scream regardless.![]()
That is a reasonable RC budget LOL maybe not to the missesbadboy2 said:well maybe ill put my cy26 stock on the redcat and get a 27.2 for the 5t or 5b..man this 1/5 thing is getting expensive.i prolly spend at least 200 a month..
