which upgrade should i get?
DougStar
Well Known Member
PLUS member
Build Thread Contributor
Crafers South Australia
im wanting to but a crab manifold up grade. i was getting some lean out from air in my fuel line fix that with some line clamps (y)
so my prime bulb is not completely running dry but its about 1/4 full after 20 mins. DDM has two insulator carb manifolds that im looking at1540392414070.webp
this one ill have to ajust the carb linkage coz its a little thinner
http://www.davesmotors.com/RB-Innov...Diaphragm-Filter-for-Zenoah-G320-Engines.html
or this one
http://www.davesmotors.com/zenoah-585727001-g320rc-insulator-manifold-billet-aluminum-ddm.html
no adjustment on this same thickness
which one will help/should i get
so my prime bulb is not completely running dry but its about 1/4 full after 20 mins. DDM has two insulator carb manifolds that im looking atView attachment 47001
or this one
get the rb innovations one (first one) its better because it has a diaphragm filter and its like a heat sink so less heat on the carby (y)
Thanx for the imput everyone (y)
And guess what im gonna go the opposite :eek::LOL:
The first one even though it has a heat sink it may restric air flow.
There isnt a lot of space under the shell and id rather have the air movig. So ill go with the smaller one i has the two gaskets. Time will tell as to how its going to work
