Will these extended front hex hubs work with front disk brakes?
Those will work but I suggest getting the dgi clipless version.
What's the difference between the extended ones and the original?
Don’t know if they will, it depends on your calliper spacing. I have these ones made by Fruitbat on here.
I have hydraulic brakes though and they could be quite different.
These are the extended ones? don't they make the front wheels wider than the rear? do you recommend them over the original?
I’d get front and rear extenders personally. I think front only would look weird. The ones you posted are an old design also. Get clipless extenders. PM Fruitbat.
Firstly you need extended hubs to make room for the disc brakes, that's why they have the 2 hex's. One's for the rotor and the other the wheel goes to. The rovan/KM set you posted picture extends the hubs out 1/2" on both sides for a total of 1" extension.
I would buy these extenders from DGI. Same 1/2" on both sides but clipless. DO NOT BUY the Rovan clipless set! They will not fit correctly.
https://www.davesmotors.com/dgi-racing-1-inch-axle-extenders-hpi-baja
Mine are Rovan extended and they fit fine
