I’m new to the MCD. I am new to 1/5 scale racing. I am used to much smallest scale like 12 scale. There is a lot to learn when putting the body together my question for you guys is are you cutting out air vents on both sides of the body?
And the side window are thick for cuttingI will post when decals are applied also but I’m really
x2 about putting the body on.
None of mine are easy.
Yes it does. There was this really generic wheel I got years ago from harbor freight or walmart or something in one of those budget bit kits. It was basically a diamond file on a disc. It sanded bodies and cut windows so good, I broke it about 10 years ago and have never been able to find another.The Dremel metallic cutting wheel does wonders touch it up with the grinding bit
YupOk thanks everyone. I see all types on you tube You guys run Wagner Park in nj any time?
This is something I really need to consider. It is around 4 hours from me (+/-) and might be a little more than a day trip between travel and playtime. Not to mention I would probably be sent home with my tail between my legs since I still have a lot to learn.
