window fittings!?
tizdaz
Sunny Northwest!
Hi guys, ive got some acrylic to make some windows for my dibby! i was going to use m2 hex bolts to fasten them to the cage, but id much rather use these:window fittings.png
they are used on the HPI Baja to fix the windows, but i have no idea what these fittings are called? any ideas guys so i can search for them separately?
Those are just 1/4" cable holders, you can find them anywhere they sell audio/video stuff. Since your in the uk im not sure what big box stores you have but something similar to home depot for us here in the US... just make sure to measure the thickness of the cage so you don't end up buying the wrong ones. But pretty sure their 1/4"
ahh ok great cheers buddy! ..we have a store called "B & Q" so will have a look on there, i never thought of cable holders!! ;)
these maybe?
https://www.diy.com/departments/qty...-armoured-screw-fixing-p/5055538198649_BQ.prd
would 12.7mm be ok for size ya think ?
all different sizes though so not too sure which
think i found some! https://www.amazon.co.uk/sourcing-m...la-797050098446&ref=&adgrpid=76297946145&th=1
ok i just measured the width of the cage tubing and its 9mm, ive found some clips on amazon that are for 8.4mm so these should be good? or should i got for smaller to make sure theyre tight ?
