Working brake lights for 5ive T2.0
mj.jafari
Active Member
sorry if been asked before, how can I get a real brake light working so it only turns on when I hit the brake ? How can I use the reverse signal going to throttle servo to do this ? Or I guess might be mechanical ways to do it using a switch that is pressed when servo moves in brake direction?
I use a cheap ÂŁ15 one from ebay for mine, also powers the front spots too. Think its listed as 1/8th 1/5th lights, comes in a nice little plastic box that can be used for spare screw storage for field bag...
Just for info, some you see will be limited to 6V, the ones I use take 2S lipo.
The controller goes inline for throttle servo and takes a feed from signal wire, its all plug and play.
