Xrc rc-2
Bong-Master
East Coast (UK) Lowestoft
hi i got the XRC RC-2 4 xmas & the XRC Pullstart 32F.07.100 is broken (cheap plastic) is there a metal/alloy pull start that will fit from one of the other 23cc engines ?
Also are there any other bits from other cars/buggies that will fit on this
Bong,
The pull starters are pretty standard and they should all fit one another. What part of yours broke? The housing itself should not break easily, the pawl inside might be stripped and it's pretty easy to replace and re-spool the line back in. You can get a metal pawl instead of the whole thing. If you really want to get a metal housing, i believe i've seen them a python rc.
Chris
The only bit i have broke so far is the inner of pull start, i was after getting metal insides as the outer casing seems to be solid unlike the pawl, i assume that the pawl is the bit that is pushed out & turns the flywheel ?
Hmmmmm nice link i will bookmark that as it loooks the nuts & would be nice as a upgrade in the near future.
Yes that piece that goes in and out is the pawl. You can get it in metal.
Is your line recoiling. If not, you might have unspooled the spring.It's pretty easy to re-spool it if that happened. The first time is a pain, but once you learn it gets easy.
Chris
Just ordered one :) just hope it arrives soon
looks like davesmotors is going to get a bit of custom from myself :) shame i cant find a uk distributer
a few on here have the same problem mate i use ddm now and never had a problem buddy :cool2::cool2: one thing though if you used thier standard post expect to wait about 2-3 weeks :blush:
Holy Bat 2-3 weeks going by that i should have the replacement parts under warranty & this part at the same time lmfto oh well s^%& happens Doh!!
Some ppl say that some of the fg mardar parts fit on the xrc -r2 but what thay have not said is what parts lol any one on hear got any clues ?
Got a fg marder pull start this morning & now the 24 tooth is major f^&*ed & 40 tooth slightly f&*^ed. nitrotek only do the crap Metal ones that came with the buggy.
any one got any info on what other's will fit on it ?
Also would 28/36teeth make much difference ?
i,ve got a new 18tooth fg pinion gear if that any good, don,t even bother with nitrotek spares there poor quality to say the least,:nono::nono:
What is a good ratio ? This is a list of what i can get at a good price i think lol £40.00
All Steel :)
48T X 16T
48TX19T
48TX20T
47TX20T
47t x17t
46t x 18t
46t x 21t
45t x 19t
44t x 20t
43t x 21t
42t x22t
41t x 21t
40t x 24t
junk it all, and fit a fg rear end, my mate got one and just kept killing gears so i fitted a fg set up, sorted, gears for all and 2 speed if you want
Not sure about the XRC but the FG gear sets should add up to 64teeth in total if I am not mistaken.......might be worth bearing in mind to obtain the correct meshing........
