dwarfy
Yes it would , providing that the breaks & the bell housing fits on the other side you can go direct belt replacing the 24t/40t gears. Going direct belt the way it is atm it would drive in reverse all the time.
The 24t goes anti clockwise witch turns the 40t clock wise witch makes the little pinion gear go clockwise thus making the diff gear rotate anti clockwise making the wheels drive forward.
hope it makes sence
Yes I know what you mean! I assume it would be toothed pulleys & belt to avoid slippage & allow you to change the gearing as you can now by changing the pinion / spur?
