savagekiller
- Reaction score
- 0
Here's my problem... It will start just fine, but as soon as I apply throttle, it takes off just as normal, then the throttle starts revving up and down in spurts, and then the engine Boggs out and dies, all in a matter of about 5 seconds. I can leave it at idle for a few minutes, but eventually the engine does the same thing, revvs up and down in spurts and then dies. I adjusted the needles to the stock settings, but still the same results. At the end, when I finally gave up... When I applied throttle, the truck didn't even move, just revved up, so I quit right there.
Could this be a clutch AND engine problem???
While the engine is freaking out (revving up and down, before it dies) the throttle servo isn't moving at all, so that can't be the problem. And every time the engine revs up, it's lunging forward at the same time... Clutch is engaging on its own?? No throttle applied by me, it does this all on its own. Tried to describe this as best as possible... Hope you guys can give me a starting point to start troubleshooting... Wanna get this figured out before the weekend.
Plan B is contacting the Vatican and requesting an exorcism.
