Don't know what you're referring to but may be this can help. 220mm fully extended (off the car). Upper bolt center to lower bolt center 215mm.Ice_2k said:The DR shocks have 195mm off the car, I'll also measure them on car. Do the shocks posted by designed2survive mount on the lower arm of the DR? I don't see the end, the part that got bent on mine.
You're right, those are 8mm.phreerider said:oh yeah, best deal out there! those are 10mm or 8mm ? only kits i have seen are 8mm.
25mm longer shocks are not a problem.Ice_2k said:Yeah, the DR shocks are about 25mm shorter... too much difference?And it sucks that these also have the lower part made of plastic, which is the part that failed on me...
Yeah, very big difference. Unfortunately it's not something you can really hear in a video unless you have two cars next to each other, with & without silencer.designed2survive said:It make a big difference doesn't it? When I tried the silenced VRC that was my same reaction. I could hear every little thing now. Lol!
Those definetely look beefy as hell, I'm gonna go this route if my new shocks get bent as well.designed2survive said:
The remaining weak point are those plastic spring retainers at the bottom end. Will run them like that and if they fail next order will be the aluminum ones.phreerider said:...man those 8mm are beefy!
