Markcarr
- Long Island NY
Rob Your like 33... STFU you dumb kidYour a dumb kid. You guys need to be told the same thing 100 times. Grow up.
Nope I’m 32 but had my first job when I was 13, joined the military at 17 and have been on my own since then. I’ve lived many lives mr. Carr so suck an eggRob Your like 33... STFU you dumb kid
Not yetyall done fuckng up my thread yet?
What branch of the military?Nope I’m 32 but had my first job when I was 13, joined the military at 17 and have been on my own since then. I’ve lived many lives mr. Carr so suck an egg
Air Force.Not yet
Only f35’s on my free time. I worked on c17 and kc-10 aircraftThat’s cool… did u fly?
yeah i try to buy as much denso as possible. all the o2 sensors i bought are also denso (gunna replace em while the cats and y pipe are getting done) . and heres a list of stuff done by the previous owner (provided recipts and everythin)She's gonna purr now! Just an FYI, when searching for parts try your best to stick with Denso if it's an option. Have you considered doing the timing belt? It should be due with the mileage you've got.
ok ill keep that in mind yeah i was only gunna buy a LS if it has had the expensive and labourous stuff done, which i have thankfully (it was the last one i was gunna even look at, if this one hadn't worked out i was gunna go buy something else, because there was only 2 others in this price range and they were poop) . Love this car so far!!You found a good one My thoughts on the trans fluids is to keep up on the drain and fills. I do mine every 2 oil changes (synthetic). 271k on the original trans in my Pilot and still going strong.
Wtf y?no. some jackass welded the fecking stock pipe to the stock cats
Why the hell would you waste trans fluid like that? I have 279k on the original trans in my expedition and it's just coming up on needing the trans service for the third time. Every other oil change is excessive to say the least, and had no bearing on transmission longevity. Matter of fact I've only ever had one vehicle go through transmissions and that was years ago, because I abused the piss out of it. Heat is basically the only thing that kills transmissions, unless something catastrophic goes, it's normal wear and tear and changing fluid in a closed loop filtered system doesn't do anything to stop that. By that same logic you should be changing every fluid in your vehicle on your every other oil change schedule. It's just a waste.You found a good one My thoughts on the trans fluids is to keep up on the drain and fills. I do mine every 2 oil changes (synthetic). 271k on the original trans in my Pilot and still going strong.
Cuz they had a welder and didn't feel like using a clamp. Normally from the cat back, or down pipe back I weld everything I can on the exhaust. Last time I did exhaust (think it was on the truck) I left the tail pipe clamped and welded everything else, save the cat (flange mount) looks cleaner and is stronger then a clamped system.Wtf y?
