old man emu
- Reaction score
- 63
hey guys can i put a zenoah 32cc top end onto a rovan 32cc bottom end without any problems,ive heard the rovan bottom end is ok just the top is rubbish.
+1Yes HOWEVER there are slight tolerance issues with the Rovan parts so its impossible to say if it will fit 100% or have squish clearance issues so be prepared to buy thinner gaskets if need be.
I've also noticed rovan parts are oddly one off a bit like the cranks are thinner and such so don't expect to not have possible slight other issues or everything might be peachy. Its a gamble really.
Its not really measured in hoursoh great do.they last a while is there an hour recommended for top end rebuilds as like dirt bikes have.
2 years??? I was lucky to get 2 Sundays out of KM engine lolIts not really measured in hoursbut a decent motor id say 2 years minimum
if you run decent oil and look after the filters
I heard motul is good. I usually run dominator. In the hard summer ill use benol sometimes but its not recommended to use below 60f.oh that's great im only bashing it every couple of weeks im using still ultra hp oil hopefully that is ok.was thinking of running motul 800 but not sure.
what oil and ratio phillI've been running my Zen 29 for over 5 yrs with no problems
I just run Havoline dirt bike oil from the servo
Same thing happened with my Rovan, they are just trash enginesmy engine is 3 hours old just run in i looked inside exhaust fitting my outerwares and seen fairly big scratches in the bore chipping around the ports so im thinking its rubbish. it still runs fine but for how long.i could just put another rovan top end on to not real sure which way to go .
did you replace the engineSame thing happened with my Rovan, they are just trash engines
