zippo855
- Thread starter
- #41
if it could be fitted, that would be sweet.I suppose it depends just how hot it is when you run it, how rich/lean you run it, and how long for.
Perhaps an old Bernie Eccleston idea may help - the old Brabham BT46 fan car http://en.wikipedia.org/wiki/Brabham_BT46 ?
Could even help you go around corners better!!
Certainly get the air moving better!!!!!!!
that was my thinking, but if i had a body to run in the cooler months it might not be bad, but during summer it would be off.i would think its gets pretty hot,having no air circulating around where
the two cylinders are together
K....
got some of the little things worked on tonight.
put fullforce extended cups on the front, didn't like the sag, much better now, and got the kraken chase cage adapter installed. had to tie it into the extension piece that came on my sc due to the pipe. but should be a little easier now. had to work most of the day, then watched the fights tonight. so hopefully going to get the other break-in tanks through it tomorrow.
