Man where do you get those stands it's sitting on?!?! I need something like that so bad lol.I have a XR5. Love it.
Little teaser for you. View attachment 87795View attachment 87796View attachment 87797View attachment 87798
That's the 2nd version of the 30°N that has the different enclosed transmission. The V1 is 100% a clone of a V1 5iveT. Only materials/quality is "different".Not that the 30*north is a terrible copy, UT one of the caps just went through all heck trying to gear his. They used some sort of one off transmission and bell housing. No way to set mesh. So thats a hard pass for me. Besides that my 5ive t has been the most reliable 1/5 I've ever owned. Still about 80% stock parts.
I'm awareThat's the 2nd version of the 30°N that has the different enclosed transmission. The V1 is 100% a clone of a V1 5iveT. Only materials/quality is "different".
Just letting OP know there's plenty of aftermarket support for the 30°N DTT-7 V1.I'm aware
Just curious...but, is the 30DN 7075 chassis identical to Losi's 6061 chassis? Can the stock chassis be swapped out for the 30DN chassis?It also has a 7075 chassis compared to 6061 on the Losi.
First, thank you for the comment...it provided more info than I expected. Second, good to know about the cage. Sounds like I'll be ordering the body/cage combo. Third, honestly, I wasn't aware there were other 5T chassis our there. Now that I know, I'll be researching them (if you, or anyone else, has suggestions/recommendations, my ears (ok, eyes, since it's words I'd be reading) are 'open'. Fourth, didn't really think a separate thread would be needed, as it was a simple question, and one I figured those having already replied within the thread would have answers to...and, I was correct. Besides, if I had, it would have been a very short thread. Thank you, again.the cage is 99% identical, only difference is the support that goes across the back where you would put your hand to reach the pull start. Real losi cage is an X and 30 dnt is a Y, thats all. The cages are very durable and everyone that runs big bores including myself use the 30dnt cage and body and they take a good beating and do not break....
Any particular reason you want the chassis so bad? You running a big bore or crazy electric? There's no benefit really and your going to bend any chassis if you wail on it hard enough. If I remember right someone tried to use a 30dnt chassis for a 5ive or vise versa and some of it didn't line up right. There's plenty of actual 5ive t chassis to choose from.
Lastly you should probably start your own threads to your questions as the whole forum will not be notified if you reply here only the people that have replied here or are watching the thread. If you start a new thread the whole forum will be notified of a new thread and you'll have better results.
I've been doing some research, in order to help me make a similar decision. After said research, I've decided to get the 5ive-T 2.0.Let me know what you guys think...
As nice an idea as that it, it's a LOT cheaper to just buy an inexpensive chair w/ adjustable height, and then remove the seat. Quite a few can be found on Amazon for less than $100, with more than a reasonable selection being in the $60-70 range.It’s a gaming chair base
https://www.amazon.ca/gp/aw/d/B09JZ8YQXC?psc=1&ref=ppx_pop_mob_b_asin_image
Office chair casters
https://www.amazon.ca/gp/aw/d/B09K76TZ1V?psc=1&ref=ppx_pop_mob_b_asin_title
Office chair tilt mechanism
https://www.amazon.ca/gp/aw/d/B0BR3TQSMQ?psc=1&ref=ppx_pop_mob_b_asin_title
20-28” lift cylinder for bar chair
https://www.amazon.ca/gp/aw/d/B09ZPNR572?psc=1&ref=ppx_pop_mob_b_asin_title
Oh and a piece of 1x8 cut 24” long and sanded with rounded corners and a few coats of varathane.
