- Queens
Got a level up from the rcs. 2011 335i coupe with the n55 engine. Ive had it for a little while already so I've done some little stuff to it already. I did the water pump and thermostat (took 2 days on jackstands in the driveway), also did the DV spacer while I was there. I got some nicer rims, carbon trunk lip, front splitter, carbon antenna cover, side skirts not installed yet. In the middle of doing the exhaust, the corrosion in the hardware is so bad I ended up cutting the nuts off with an angle grinder, chassis brace bolts are horribly seized on tho, broke 4 torx sockets (including an impact one) tried an impact, heat, soaking in rust remover, breaker bar, air gun. Kinda unsure how to continue, seems like I cannot find any good quality bits, really don't wanna break the bank and order the snap on or matco ones. Any ideas for that?
