I have pictures in my gallery but cant figure out how to send to you.Shows what I did to not cut cage.if you can work me thru i ll send.I tried to gmail to https://www.largescaleforum.com but showing me invalid site.....
That would be appreciated Mick, thank you.
Did you want to openly share with all or discreetly share ?
If openly with all, you should be able to start a reply and then below the reply text box and “before” you submit your reply select attach files. Then you can select the pictures that you desire to share. After this you’d do as normal and select post reply.
Might be too many pictures try only fourWill try .I am hitting paper clip,selecting images,selecting all but not letting me come back to send
