G340 full mod won't start
cardarear
Oakland County, MI
Would anyone like to play the "it won't start game"? So here's the deal. Engine was starting and cutting off a week ago and no it won't start at all. Probably my fault but I can't figure it out. So here's what I've checked it noticed.
I can't see the spark by grounding plug to the top of the head but the tester does light up.
Tried 3 new plugs
Replaced ignition coil
Tried with and without kill switch wiring
Checked for correct spark plug type and gapping
Mixed fresh fuel (28:1) in case spark not the problem
Checked for flooding by removing carb and also turning upside-down with spark plug removed.
There is fuel in bulb and return line and plug comes out wet.
Carb and air filter bolts are on tight
Bolts from head to crankcase are tight.
Breather hope in gas cap is clear.
Air filter is clean ( vehicle always runs with all three outerwears)
I would check for compression but not sure what I'm looking for.
I've already sent an email to OBR for help but does anyone have a suggestion for something I should check?
Tried 3 new plugs
Maybe the flywheel key sheered. You'd probably notice but I'd just check to be sure. Maybe you over oiled your air filter? Try resetting the needles to stock settings. Check the pulse hole on the carb , maybe it's blocked.
OBR? Which one? Mine has been insufferable lately. I've been looking at the carb, though, for contamination. When warm/hot it won't prime. Even when cold it's been a BEOTCH. Suspecting vaccum leak too- somewheres.. But I've got plenty-o-compression like Crucial says.
Still not replaced the carb to know yet.
I assume if the flywheel key sheared the flywheel would be free spinning and the piston not moving. The piston is moving. Air filter has not been reoiled lately since car was only run on road and with outerwears. I forgot to mention in the original post but I have a 990 carb and I did reset it it to 1 1\8 low and 1 5\8 high. I will check the pulse hole on the carb and gaskets while im at it.
Reset your needles ?? start at the base setting H 1 7/8 L 1 3/8 and when you adjust your needles do only 1/16 turns don't go nuts??
990 carb was reset to default settings 1 1\8 low and 1 5\8 high
No it will still spin the crank Because of the taper. Mine did
What was it sounding like when it was cutting off ???
If you were really lean and kept driving it like so. You could have fried the engine ?
other things you can check is for broken fuel lines ??
It just slowly lost revs and died. I was just keeping the revs higher than a normal idle but the car was still stationary. Did that for about 30-40 seconds then eased up on the throttle to see if it would idle and it died.
I did add quick disconnects about three weeks ago. I checked the chassis and surrounding area for leaks but didn't see anything obvious. I will have to give it avoid clean and recheck it again next time.
So can I check for this without removing the flywheel?
You would know if the compression was gone on an obr. How easy is it to pull the pullstart?
Not easy at all. It kind of sucks.
It's the G340 full mod (non Reed case). That compression- it's fine when it starts in like 3 pulls, but when it doesn't, it's really rough.
Ok, thanks, was actually curious if it was a REED engine. Dumb questions: Is the fuel bad/ sour and a decent 2 stroke oil? Bad fuel source? Pinched fuel lines?
How about the gap from the coil to the flywheel.
And those gaskets from the carb to intake, like Z said. Maybe you got that lil pulse hole clogged with some shtuff.
I used the gap tool from DDM when I installed the new coil. The gadgets and pulse hole hole I will check tomorrow. Thanks
First, deflood it. Set it on something so all 4 wheels are off the ground. Pull carb off engine(don't need to disconnect). Pull until it fires. It will wind out then die. Reconnect everything, set carb to base settings (not dougstar settings) and try again.
You said you removed the carb but didn't mention starting it to clear it all out of the crankcase
I tried to clear it out but it would not start. I think I'm going to have to figure out my primary issue before I can do that.
Update for today:. Pulled the engine back out. Rechecked the ignition coil and found out that wire on the back side was not connected properly. I think I tried to make the connection without fully removing the coil. The blade of the coil was between the back of the terminal and the plasticc covering instead of inside the terminal. Fix that and reinstalled and re-gapped the coil. Also checked the carb pulse hole and intake and carb gaskets. No issues found there. Still won't start. Removed the carb and tried to start it in case it was flooded. No luck. Next I'm ordering a new carb. So I will try again when that arrives.
You ever try putting fuel down the plug hole to see if it will light off?
