old man emu
hi men just checked my rovan 32cc squish as home with covid only had 1.6mm solder and it didn't squash it ,sounds like way to much gap would i benefit from changing base gasgets??
yes all good thanks stripped it down and alot of scratches so not worth spending money will run it till it dies and bin it .Any bump in compression will help some. Don't know how much you'll notice, but should run better.
Take the gasket out this will help a lot on the powerband .032 is the optimum squishyes all good thanks stripped it down and alot of scratches so not worth spending money will run it till it dies and bin it .
i actually checked without the gasget and still 1.3 mm so waist of time .zenoah will fix it.Take the gasket out this will help a lot on the powerband .032 is the optimum squish
Try closer to .020".Take the gasket out this will help a lot on the powerband .032 is the optimum squish
i couldn't do anything its a rovan, useless rubbish.Try closer to .020".
You basically said iridium plugs are superior which I agree with..Iridium plugs don’t give a better spark than a normal plug if anything they are worse. They just last longer in more extreme environments like high compression turbo charged full scale cars. I think Iridium plugs are a waste of cash in our
Hello Milo I think you misunderstood the previous enquiry,about the head clearance enquiry,,and the port timing changeIridium plugs don’t give a better spark than a normal plug if anything they are worse. They just last longer in more extreme environments like high compression turbo charged full scale cars. I think Iridium plugs are a waste of cash in our motors.
Iridium plugs transfer electric current faster.Iridium plugs don’t give a better spark than a normal plug if anything they are worse. They just last longer in more extreme environments like high compression turbo charged full scale cars. I think Iridium plugs are a waste of cash in our motors.
HelloAny of you experience interference issues running the iridium plugs? Tried them in my marder and they'd make my servos go nuts. Alloy servo plate but don't do it with the regular cmr7h.
