John Parks
Print my own
That's a breather vent incase the stock vented cap blocksWhat's up with the fuel filter on breather line?
It's a ball and spring style check valve, instead of the plastic and rubber flap style of the stock cap. It should be fine unless it gets dirt and grit jammed into it during flips or running upside downGoing to see how it works out. Seen it a few times now with no problem. Hoping it doesn't leak but guess I'll see
Good eye, I just saw it and assumed it was the valve, my badWhat's up with the fuel filter on breather line?
We run the hard ones like that on some of our dragsters with no problems. Not sure about the felt ones with dirt present.Going to see how it works out. Seen it a few times now with no problem. Hoping it doesn't leak but guess I'll see
