Seaducer hydro build thread
Little update: this engine has the right ingredients to run methonal so ill be trying it out shortly. Reed case, high compression, esp updated reed top end with championship porting, the engine is a 29.5
I made a methonal v stack out of delrin as I've been wanting to give it a shot. Delrin is interesting to work with and you need alot of speed on the lathe and good bits as I've learned. I've also made a delrin insulator as I felt something was missing and also felt if I put the carb right on the cade it would vapor lock, but the methonal should actually prevent it.20230709_000719.jpg20230709_000747.jpg20230709_171615.jpg20230709_171622.jpg
