atom3624
I'd start with very simply checking the needle settings.
Also, if it 'nearly fires' with the choke on, don't pull the cable again, just open it and fire as normal.
It's probably the needle settings. Check with other threads on this topic. This should be very simple. Another comment, are you certain the cap is on the plug properly, and the plug is in 'firmly' (not too tight) ?
Al.
Al.
