did you do a clutch spring change when you rebuilt? that might have soemthing to do with the boggyness of it. if not most likley the tune. back to stock and adjust from there is the go.
Went out with Ben today for the 1st run after all the mods & it ran well after a quick tune of the new carb. Nothing fell off & no damage apart from a crack in the wing and the roll cage is a bit bent from my bad driving over the jumps :scared: Diff works a lot better now its got some grease in it!!
Oops!! The robin.....sorry leo was running well tho between repairs :lol:
It good stuff to be able to withstand the torque. Are you going for the flat spot on the shaft?
Hope its a simple fix mate - them wheels look awesome :cool2:
i can always get the welder out then the little fekers defo wont come off :lol::lol::lol:
Do you need any parts Ben?
J
are you doing both sides to be sure or just the problem side?
hows your hearing after an hour with the x-can :gunsmilie:
