Junk again
I went ahead and purchased the new gear boxes front and rear and also was told when i bought the front and rear differential that they were the NEW and HARDENED STEEL gears.
Well guess what I went to play again last weekend and only played on the level flat dirt and YES the front and rear differential gears stripped again first was the rear gears and then when i notice that the car was a little slower I was about to quit playing and drove the car over to me and before i could get it back to me the front went and stripped on me so had to go retrieve it from the ball field.
Well the upgraded ALLOY mid box assembly held together
As you can see in this picture the gears are gone In the front and rear gearboxes and if you notice closely the MELTED PLASTIC on the differential , also some melted pieces laying there as well,its the gear box that is melted and the screws that hold the differential main gear on has back out. I purchased these completely assembled so NO i didn't put them together and not use lock tight to keep the screws in . I would have thought that the factory would have. Done all of this when they told me these gears were the Upgraded ones assembled.
Also if you look at the ALLOY mid box they sent me one fully assembled is good but look at the other one I was going to transfer the gears from the plastic one to this new housing but it wont fit,, you will notice that the holes are cut different and the bearings wont fit in it and this company try and tell me its my fault that the holes are different sizes. (I don't get that conclusion) I just order the parts.
This company is really a joke because they build a car that is strong looking but weak in the most important area the drive train. Once I mod the shock tower braces and took 4 of the shocks off and oiled them right and did a few other mods everything is strong enough on this car to be a really tough car but am Finding it very hard to find any kind of differential gearing to fit in the stock gear boxes. The only problem I am having now is the differential gears everything else is corrected BY ME to make it good.
Just need the DAMN company to do the right thing and supply me with Proper gears that wont break in the first 10 minutes of play of normal use.
