HI GLEN
i don,t by alot from him unless i have to but so far its been holding up for me and i run full on and do a little jumping nothing real high the only problem was when i was runnig in hard snow and was jumping in and out it was fun till i broke steering knuckle, then i modified with titan knuckles couple washers and stearing arms from tighten removed rod and used all thread if it realy takes a turn for worse ile modify hole thing well wish you luck and that you get it to stay together jim
Well I don't know if that engage has parts for this thing because so far I haven't found anything that even matches anything in the car only thing I know that will fit are the FG wheels nothing else seems to be even close so far .
The center Reverse diff case is built very strong and use spider gears and ahvent broken at all only the plastic case cracked .
But I don't know what they were thinking when they decided to use planatiary gears in the rear and front diff cases. I think if they used the same gears as the center reverse diff case this truck would be very strong.
The other mods that would have to be done would be the shock tower braces and that was an easy fix.
You can buy just the reverse center diff case completely assembled and it works very well and am adapting it over to my other RedCat rampage TT so it will have reverse.
here is a pictuer of the rear and front diffear assemble and as you can see its very cheap metal the internal gears are POT metal and I am serious at only just a few runs the length of a ball field they stripped and teeth torn off.
Mid alloy box shown complete is 140 USD
Front and rear gears are 61 USD
Here is also a picture of the center reverse diff case and if they would have only use it these problems wouldnt be
