chinapioneer
New Member
- Reaction score
- 0
powerful CY 26CC gaoline engine
2.4G LCD 3-ch radio system
Sensitive Reverse system
*ITEM NO.
*NAME: KING BLUE DEVIL
Brand: SY-4WD Racing
*Features:
1) Fully assemble ready to run chassis.
2) Fully powerful CY26cc/27CC/29CC engine equipped with slide carburetor pull-starter.
3) Equipped with muffler accelerator and new air filter.
4) 4WD system with shft drive.
5) Differential with the built-in rear bevel gear.
6) Adjustable width of doble fork suspension system.
7) Strong oil-filled "double" shock absorber.
8) Stiff and sturdy 4.0mm 6061-t6 aluminum chassis and side plate.
9) Standard disc break system and optional hydraulic brake system .
10) With sensitive Reverse System.
11) Full Steel Differential gears.
12) stong aluminum sheld with red or blue corlour.
13) super sensitive super steering system.
14) super strong front and rear bumper
15) Aluminum servo mount
16) super 6.0 aluminum front and rear upeer mounting plate
17) 620CC fule tank
18) 2.4G LCD radio
19) 20KG/25kg/33kg/cm Steering Servo, 15kg/cm full metal Throttle Servo and 3kg/cm Servo for Reverse System.
