rovanmadlunatic
- 1
- Thread starter
- #21
i bought a zenoah piston for my km 30.5 it is taller after lapping the top of the cylinder with the stock gasket im at .014 squish. i had to surface grind the washers to get them to fit think i had to take about .004 off the washers to make them fit nicely. im also running a reed block so i added windows and lightened the piston a bit.
the plating on the cylinders suck but that didnt stop me from trying to make some extra pony. im on my third motor build with the km 30.5 now.
30.5 cc engines do have the +2mm crank shaft - Unless the KM is not catagorizing the engine correctly, which could be the case as well.
I would look at a +1mm to see if that would allow the port to stay closed & see how that would work.
Lots of options in these little engines, but messing around with a sub par build like this seems like a waste of time and money to me.
It is your project though, and as long as you are happy doing it, More power to you !
A 1mm crank will make the problem worse The farther up the piston goes the bigger the opening. I tried a stock zenoah to see if the Km piston had too short of a skirt. None of the standard pistons I tried would fix it. The plating in mine looks much better than the one on Km's website. Maybe not last as long as a zen but I expect it will hold up for a while.If it blows I haven't really lost anything. I was stuck with the parts anyway so the money has already been spent. I personally don't consider it a waste of time cause its what I enjoy doing.Anyone can go plunk down 700.00 for a modded motor. I get much more enjoyment outta doing it myself, especially if i,ve had to think out side the box a bit to get there
