Vekta 5 common problems
one2boost
Maui, HI
I'm looking for info on the Vekta.5, what are some common problems with it. Also, has Kraken addressed the problem with a design change in production of current kits.
I've tried searching via google, and found these problems:
Rear shocks pop off top mount - seen a few aftermarket solutions along with home made stuff.
Rear lower end links breaking - many aftermarket companies offer metal parts.
A guy I race with has been braking rims so he got ddm alloy rims and started braking stub axles. He also got IRP upper rear links and the alloy mount. Seems like he has also replaced clutch bell bearings a few times.
I would avoid purchasing Jofer RC Solid Wheel Nuts they do not tighten down on the wheels.
I recently had have wheels come off just light bashing in grass with no jumps.
William E. Burrows Jr.
AKA: 5th scale whisper
Man where do I start, the Vekta.5 has so much potential but it seems Kraken released it and than said oh well and never fixed any of their issues. First off the since day one they have had shock issues such as with big jumps the shock popping off, second issue with the shock which I experienced yesterday was that the bottom cap of the shocks unscrew themselves which than dumps the fluid all everywhere. I put outerwears on my shocks Day 1 of owning after seeing fluid everywhere I knew what happened. Drug the thing home and remove all the rest 3 of the 4 were completely off but only 1 had the bottom piece fall out and dump fluid.
For the shocks popping loose a few companies make a kit which fixes this issue and low and behold Kraken fixed it with their new truck.
Mine came with several NOT even tighten flush screw and a few that were beyond tight. The Transmission plate have huge issues with bearings not staying in place that you have to use Loctite 638 which yet again this issue has been fixed with the new truck also.
Is the truck super cool looking.....well duh look at it hahaha had I known all the issues still weren't being resolved since day 1 I would have skipped this truck. It brings me more frustration than any other RC i have ever owned.
Dear @Iceman2733,
This is how I see it. I have gone through two (2) Losi 5ive-T's, I updated all the weak parts with high end parts even those have failed down the road. These vehicles are high performance in turn means high maintenance.
Thats part of the hobby, in the 80's 1/8 scale off road used chain drives you could only get one run without all kinds of failures.
I though after all these years 5th scale would be problem free, not the case.
Love it or leave it.
Best Regards,
@William E Burrows Jr I agree completely. It doesn't however mean that you should put up with shoddy construction. I think the wildfire popularity of the Vekta caught Kraken with their pants down and corners were cut at times to keep up with demand. Some report that their truck is though enough to withstand an impact with a brick wall and others complain that the fiddlesticking thing is made from Japanese folding paper. The QA seems to be all over the place with it unlike say, Losi's 5th scale which may have a lemon here and there but which generally you can take their build quality to the bank. At any rate if you don't like tinkering with stuff 5th scale regardless of powersource is not for you, is for certain :)
Dear Thrasher,
In my younger days I was a machinist.
Just comparing the diameter of the parts to the Losi 5ive-T is no contest.
I have fully upgraded the 5-T and still there is no contest.
The best way to appreciate the Kraken Vekta 5 is to build it from the ground up and upgrade parts as you go.
If you want quality you have to pay for it.
Productions models cars, motorcycles you name it cannot compete to custom.
It's just how it is.
Best Regards,
William E. Burrow Jr.
AKA: Have not crashed in a while.
All Good.
just make sure every thing is tite i ran with a buddy n my trailing arm fell off 15 mins into break in my throttle servo went lost my set screws in rear drive shaft but found them all just go threw n loc tite evry thing b for a good bashing session
the naked gun facepalm GIF
Things I can think of:
Once you get the truck, pull the entire thing apart back to kit form. You can do it in 3 sections to make it easier. Rear axle - chassis - front.
1 - Rear axle outer hub bearings and pinion bearing may need Loctite 641 retaining compound put on the bearings to stop them spinning in the housing and wrecking the housing/axle.
2- Remove the dust shield from EVERY bearing and check for proper lubrication. I have found many that were bone dry.
3 - Check the clutch-bell spins without any wobble. If it has wobble, remove the split washer and replace with a normal washer of the same dimensions might help. (you may never get it perfect, but use common sense) If the transmission is not assembled correctly it will cause clutch bell wobble. Every bearing must be seated all the way down, and the two case half's perfectly lined up. The transmission looks really simple and idiot proof, but if you don't put it together properly it will cause clutch bell wobble and tight spots/binding when spinning it over.
4 - Put small springs between the brake pads. The brakes will jam up occasionally without them, and make a constant whinnniinngg noise while driving. Be aware, the gap between the brake bolts that the springs go over and the brake disc is very small and may chew up the spring. You may want to slightly reduce the diameter of the brake disk 1/2mm if you have the ability. 1/2 to 1mm gets the disk about perfect.
5 - Make sure EVERY metal to metal screw is threadlocked. (I just use Blue as my cars get pulled apart fairly regular) pay attention to the front caster blocks! they like to come loose there.
6 - Make sure the top/bottom shock caps are on snug.
7 - Steering bell-crank has a fair bit of up/down slop in it. Shim it out and it will improve steering response.
8 - Make sure the pinion output yoke on the rear axle is at the same angle as the output on the transmission (make both parallel) also make sure both U's match in orientation or you will get binding issues on the prop-shaft and significantly shorten its life.
9 - Put 1" diameter shrink tube around drive yokes from transmission and front pinion output, to contain the threaded pin if it backs out.
10 - When installing the engine, tighten the x3 clutch housing bolts first, then check that there is ZERO gap between the chassis and the engine block where the x2 rear engine bolts go into (I use a bit of paper to make sure it will NOT slide under) If there is gap and you tighten them x2 bolts down it will screw up the alignment and put stress on the engine block/clutch/transmission ect. If there is a gap it must be shimmed out!
11 - Put limit straps on rear axle. Might sound gimmicky, but that axle/wheels have some weight in it! and it's all hanging off the piston in The shock when fully extended. Limit straps will help keep your shocks happy. Even a shoelace is better than nothing. Of course actually set the limit strap up correctly, not just have it dangling there for looks.
12 - The stock thin silver servo mounting screws really like to back themselves out and are basically garbage, especially on the steering servo. Use some beefier screws of the same length and ad a washer to the top too.
13 - The pins on the dog-bones some times come out. Take the pin out and clean it, then put a dab of JB Weld inside the hole, then re-insert the pin. That should hold it a bit if the grub screw loses tension against the pin. (happened to me today on the front wheel).
14 - Put Loctite 641 retaining compound on the front hub axles. My axles were spinning inside the hub bearing due to a slightly lose fit. The retaining compound will ensure it's the bearing that does the spinning! and prevent the axle spinning inside the bearing, metal on metal and wearing it out. Same with the rear pinion, and rear axle shafts. Make sure its the freshly greased bearings doing all the hard work and not having parts just spin inside the bearing.
15 - I really like the Vertigo quick releases for the cage and the gas tank. Makes maintenance a bit easier.
16 - I like to put a small piece of low density foam (pool noodle or similar) in the front and rear drive cups for the centre shaft, to dampen out the shafts forward/Aft slop. It makes it a bit quieter and maybe smoother. Just enough to dampen, not jam packed and tight.
NOTE: When using the retaining compound do NOT use the high strength one or you will never get the parts to separate again without destroying bearings ect. When using the retaining compound 2 drops is all you need. 1 drop on each side, it will level its self out. Even the Medium strength retaining compound can be very strong!
That is the main stuff I can think of, that I have had to deal with.
The Vekta is a awesome truck once you get all the small details sorted out. If you don't take the time to build properly it won't be much fun.
Kraken design really cool cars! That being said, I feel Kraken would do better to stop offering their models as ARTR and just produce kits.
As another member mentioned, Krakens are high performance models and require proper maintenance with a keen eye to attention to detail.
3 - Check the clutch-bell spins without any wobble. If it has wobble, remove the split washer and replace with a normal washer of the same dimensions can help. (you may never get it perfect, but use commom sense)
4 - Put small springs between the brake pads. The brakes WILL jam up without them.
6 - Make sure the top/bottom shock caps are on tight. A single wrap of thread tape can help if needed.
8 - Make sure the pinion output yoke on the rear axle is at the same angle as the output on the transmission (make both parallel) also make sure both U's match in orientation or you will get binding issues on the prop-shaft and probably break it.
10 - When installing the engine, tighten the x3 clutch housing bolts first, then check that there is ZERO gap between the chassis and the engine block where the x2 rear engine bolts go into. If there is gap and you tighten them x2 bolts down it will screw up the alignment and put stress on the engine block/clutch/transmission ect. If there is a gap it must be shimmed out!
That is the main stuff I can think of.
The Vekta is a AWSOME truck once you get all the small details sorted out. If you don't take the time to build it properly it will just rip itself apart.
Kraken design really cool cars and is the only brand I buy 1/5 scales from. That being said, I feel Kraken would do better offering all their models as kits as in my experience they need attention to detail when building them, or they become a pain in the a$$ fast.
As another member metioned, Krakens are high performmance models and as such require proper maintnance and attention ot detail.
Very good advice.
wow, I started this thread over 8 years ago. Since then, I have picked up another Vekta5 and have another Vekta5 chassis build on the stand.
