FID Racing DH
Reading the Rules!
Specification:
L*W*H:950mmX540mmX355mm
Length:931.6mm
Wheelbase:616.5mm
Front tire track:457.4mm
Rear tire track:461.4mm
Max speed:75km/h
Big chassis: 5mm 6061-T6
7mm Thick Shock Shafts
235mm Long CNC Alloy Bodied Rear shock Absorbers(225mm Hole to Hole)
185.5mm Long CNC Alloy Bodied Front shock Absorbers (175mm Hole to Hole)
61 Tooth Steel Main Spur Gear
20 Tooth Steel Pinion Gear
Fuel tank capacity:750ml
Body shell: CLEAR, With 2 Full Livery Sticker Sheets
Alloy front/middle/rear differential gear box
Off-Road tyres:179x75mm
More than half parts are alloy parts
RTR Net weight:18.5kg Gross weight:24kg
Engine Radio Gear and battery are not included
Carton size:101*60*41CM
Included in the Build:
Billet Alloy Front Shock Tower
Billet Alloy Rear Shock Towers
Billet Alloy Front Swaybar Brace
Billet Alloy Front Bumper Mount
Billet Alloy Front Top Plate
Billet Alloy Front Diff housing
Billet Alloy FULL Centre Rear Axle Diff Housing
Billet Alloy Front Chassis Brace
Billet Alloy Full Steering Set Up
Billet Alloy Center Bearing Holder
Billet Alloy Full Center Diff Tower & Brake Calipers
Billet Alloy Pinion Holder/Engine Mount
Billet Alloy Small Engine Brace
Billet Alloy Rear Swaybar Arms
Billet Alloy Shock Caps All Round
Billet Alloy Trailing Arms (Polished Silver)
Billet Alloy Upper Four Link Ends With Rose Joints
Billet Alloy Fourlink chassis mounts
Billet Alloy Fuel Cap & Filler Neck
Billet Alloy Extended Wheel Hexes & Caps
Billet Alloy Radio Tray Plate
Billet Alloy Rear Top Plate
7075 Turnbuckles
Item's Also Included With the Roller:
CNC Alloy Small Engine Mount
CNC Alloy Adjustable Throttle & Brake Linkage Set Up (Including servo Horn 15 Tooth Splines)
CNC Alloy Adjustable Steering Horn, With 'Push Pull' Linkages (15 Tooth Spline)
CNC Alloy Pinion/Clutch Housing To Engine Spacers & Chassis Mount
CNC Alloy Engine Spacer Chassis Plates
Alloy Servo Screw Spacers & Screws
FULL Air Filter Unit (Including Housing, Filter, Top Plate)
Fuel Line 'Anti Pinch' Springs
Bolts for Small Engine Mount
Screws For the Engine to Chassis
Bolts for the Pinion/Clutch Housing
Bolts for the Air-Filter
Gasket for the Air-filter
2 Full Sheets of Livery Stickers
Battery Tray Dimensions:
150mm Long 32mm Wide
40mm Deep, (45mm with the Lid on)
