ooohh my bad. just got confused
Ahh no big deal lol. I thought the OP put those stickers on his truck. So I figured he knew what company they rep'ed.
Those controllers are actually really good! ?
ultimate will give you slightly more power but will run hotter vs standard will have slightly less power and run cooler, either one is good just depends if you want to spend a couple more cents. i ran standard in mine and it had plenty of powercool im glad its a good one, now one thing im not shore about is fuel now do i use ultmate or standerd ,ive just ordered castrol xr77 oil
ill run standerd then thault ultmate may be beta for engine but running hotter sounds not so good![]()
Ethanol is a a additive that most all petrol you can buy at the station have. It's basically alcohol and why we rc guys don't like it because the alcohol in the fuel makes the fuel lines and diaphragms in the carburetor go bad after a certain period Soo you want to eliminate that, if you can't find ethanol-free petrol than you can add ethanol stabilizer which will pretty much remove the ethanol and you'll have you problems. I recommend star Tron ethanol stabilizer for the best results. http://www.starbrite.com/item/star-tron-gasoline-additive?category_id=586 make sure to get the one for small engines cuz if you don't I not sure if your engine will run right so make sure to get the small engine stuff ?How do you no if it's non ethonal
No problemcheers for the info every one![]()
Some gas stations sell non-ethanol. There are a couple near me that sell it but it is getting less common.
Yes here are the ones I recommend, volt watch, throttle servo, 4000mah battery, hostile spur gearing up, exhuast (the exhuast you have is a clone of the hpi ss pipe which was made for a 23cc so it won't help your Larger engine) and 990 or 813 carburetor, also only get the clutch when you no need one because sometimes there good sometimes not, my clutch lasted 7 months. When you do get a clutch get this oneare there any hop up grades that are worth doing for the km t1000 fancy air filters ect or cluch upgrades
