Whoduh
I did not know HiLantronics started making servos.
Price point is $159.00 US. that sits in between the Hitec D840/845($99.00) but closer to the Spektrum 9020/9010 ($189.00)
HLT4000WP High Torque Digital Servo -
<<< New Product >>>
The HLT4000WP High Torque Digital Servo -
Designed and Manufactured in Australia.
Unbreakable fully billet casing, waterproof*, 15T gear teeth, heavy duty metal gears, high quality coreless motor, smart digital signal controller with Led status signals for diagnostic, quick disconnect servo lead, current limiter and over temperature shut down if servo ever got stuck to prevent the controller board from being burnt out, automatic shutdown if no RX signals present.
Servo require 3 to 5Vdc square wave pulse. Pulse duration is from 0.9mS to 2.1mS with 1.5mS as center. Servos can be operated within a 6V-8.4V. range. The Black wire is 'ground', the Red wire ( center ) is 'power' and the third wire (white) is 'signal'.
HLT6000WP High Torque Digital Servo -
<<< New Product >>>
The HLT6000WP High Torque Digital Servo -
<<< New Product >>>
- LED Signal Status:
- - Green Flashing: No Radio Signal / Inactive
- - Red Flashing: No Radio Signal / Low Battery / Inactive
- - Green ON: Active
- - Red ON: Low Battery voltage (Below 6 Vdc)
- - Red/Green ON: Safe Mode (Current Limited)
<<< New Product >>>
- - Red ON: Low Battery/ Current limit mode/Low Battery voltage (Below 6 Vdc)
