Custom 70cc engine build
Is it worth it or stupid?
  • YES
    Votes: 21 63.6%
  • Hell no
    Votes: 2 6.1%
  • Kinda
    Votes: 4 12.1%
  • YES
    Votes: 3 9.1%
  • Nah I'll pass
    Votes: 3 9.1%
  • Total voters
    33
Update: sooooo I ordered 2 more pieces, clutch and axke boots. This build is not just building the engine I'm also making the truck be able to handle the power. So my next part will be a team chase clone cage, don't want to get the original team chase cage only becuase Ive heard good things about the clone so I don't want to spend the extra 50. It's gunna be the cage and parts to install it because at the moment the truck is a Baja 5b not a 5t. I will post pictures of the cage, clutch, axle boots when I get them. The next most expensive piece after that is the clutch bell which is 50 bucks so not bad, then kill switch, then it's small stuff. The hardest part is Gunna be cutting and welding the exhuast, making exhuast flange and brackets, making clutch housing, clutch plate, and the Crank balance/trueing/con rod replacement, not Gunna do the Crank balance/trueing/con rod replacement becuase I don't have tools for that nor do I know how to balance and true a crank.
Update: heres the axle boots
They were a PITA to get in but here's them installed on my junk
Really messy and sticky (lol) and annoying but it's on. Also here's the fs clutch
The alx 71cc crankcase is designed for a 70mm clutch, I'm not using that cuz I'm too poor at the moment but I will get it soon, it should be fine cuz I'm running a small carb so the power is limited to like 12hp
Also I'm not Gunna use the stupid little bullet connectors that the Marine coil come with
Instead I'm Gunna use xt90 connectors and this is how it's gunna work
I know it's a little over kill but I don't really want to burn (sometimes I do) down my truck and it will tidy stuff up alittle ?
I know you guys say the bumper belongs on it but i think it looks killer without it or up close to it like the Vekta 5 or bajas
I agree, with the baja 5t front bumper on the TC cage the gap is like a grand canyon! I don't like it. I'm either gonna get a rpm bumper, make one, or just none at all. Also I'm not sure why but it kind of looks like a vekta alittle to me, dunno about you tho. I used to hate the tc cage but know I love it
Good answer(y)
Ok I'm not sure if I mentioned this but I'm going to now. The exhuast I'm using is from a yz85, the inside diameter are theoretically correct so it should work just fine performance wise.
It's honestly a complete pile of crap, but it should work. It obviously is never going to fit the way it is do I plan on taking out like 2.5 inches out of midle (I know that will mess with the expansion chamber) of it for it to be fit. The header will get cut off, and remove like 3 inches, add a flange for it to mount to the cylinder, and weld it right back up, and of course cut that big ass stinger. Eventually I will get a proper DRP alx side pipe to replace this but it will have to do. I won't be doing the welding (of course) but I will be doing the cutting.
if you are using a panel kit the rpm bumper wont work. It sits to far back so its actually under the hood. If you don't like the 5t bumper, the next best option is the 5sc bumper
