Yeah Il probably get that and trim the sides alittle cuz imo it's a bit too wide but that's a easy fix ?
I don't know how much pushing and pulling you had to do to get the cage to fit correctly on the chassis . But I did a little reading the other week and found some good advice . Soak the cage in the bath tub in hot water only ,for about 20 min. this will make the cage a little more flexible . After 20 min or so pull it out and put it on the buggy and install all the pins and let it cool down. The chassis should hold the new form. I tried it today and it does make it go on easier .Update: gotta package ?
Its a team chase clone rollcage and parts to install it
This will take a beating!
Yea the back two pins are a PITA to get in, I'mma try this, thx ?I don't know how much pushing and pulling you had to do to get the cage to fit correctly on the chassis . But I did a little reading the other week and found some good advice . Soak the cage in the bath tub in hot water only ,for about 20 min. this will make the cage a little more flexible . After 20 min or so pull it out and put it on the buggy and install all the pins and let it cool down. The chassis should hold the new form. I tried it today and it does make it go on easier .
It works . Those were the 2 pins I had trouble with too.Yea the back two pins are a PITA to get in, I'mma try this, thx ?
I'mma try that after dinner thx ? hope it works cuz I'm not a fan of fighting to get the cage offIt works . Those were the 2 pins I had trouble with too.
The back pins were really tight on mine too. Used a hobby knife to trim down the diameter a little bit?I'mma try that after dinner thx ? hope it works cuz I'm not a fan of fighting to get the cage off
Mine don't line up without a bit of stretchingThe back pins were really tight on mine too. Used a hobby knife to trim down the diameter a little bit?
Those were fine fir me, i was taking about theseWere talking about the chassis pins that are just before the engine or at the engine. Atleast those were the 2 I had trouble with .
Those were the ones i was talking aboutThose were fine fir me, i was taking about these
Those lined up fine for meWere talking about the chassis pins that are just before the engine or at the engine. Atleast those were the 2 I had trouble with .
so you made the hole bigger?Those were the ones i was talking about
No, i trimmed a little off of the diameter of the pinsso you made the hole bigger?
Ok, I'll do that. The technique that @1Coopgt told me did make the cage more flexible and now I don't have to stretch the cage to get the back pins to line up but I still have to hit it a couple of times to get the actual pins in the holes so I'll trim them nowNo, i trimmed a little off of the diameter of the pins
Hey man, km rovan quality isnt always consistent, but with alittle effort it'll work ?Interesting ,those I didn't have any trouble with.
The cage is plenty tough even if it is KM. Trust me mine has took some hard tumbles and nothings broke yet?Hey man, km rovan quality isnt always consistent, but with alittle effort it'll work ?
What I mean is that the molds aren't very consistentThe cage is plenty tough even if it is KM. Trust me mine has took some hard tumbles and nothings broke yet?
