don't try to put the titan pipe on it.....it will fit because its the same chassis but you cant mount your cage anymore..... I'm running a Hpi can hollowed out
The arms/bones are shorter, than the titan, the shocks are also different...1 good thing the bones haven't poped out......and I will try!!
.............................T-Bolt..................................................
Length............................................700mm
Width.............................................460mm
Height............................................286mm
Wheelbase......................................520mm
Tread(F/R)......................................458mm/460mm
Wheel Diameter...............................172mm*80mm
Gear Rate.........................................8.4:1
Weight...........................................12KG
Engine............................................28cc
............................Titan......................................
Length -------------------------------- 750 mm
Width --------------------------------- 540 mm
Height -------------------------------- 300 mm
Wheelbase(F) ------------------------ 500 mm
Wheelbase(R) ----------------------- 570 mm
Tread(F/R) --------------------------- 520 mm
Wheel DIA.(F/R) --------------------- ?200*110 mm
Gear Rate ---------------------------- 11.4:1
Weight -------------------------------- 12.4 KG
Engine -------------------------------- 28 cc
That jingle is not a fixable item...all steel gears off the clutch... heli cut gears on the diffs...The Titan has the same jingle...ask any owner of a 4x4 1/5 smartech.....
That BMX track is new.... only problem is they don't have a podium to stand on so you can maintain constant visual .....has alot of blind spots
Hey atleast the buggy is fence proff
tank ##3 ballfield
http://www.youtube.com/watch?v=3r9v6iYQZI0
here are some links to photos of the buggy
Look at this photo you can see how they made the roll cage with pins for taking it apart in different locations
