Hi all
Got my Losi running today after work,
Replaced coil, replaced motor mount screws (after removing bad 1) with Stainless Steel ones
when I first tried starting, could feel the compression but no pop's, so pulled spark plug and it was wet (that's never good) pulled motor over several times, installed new plug went back to stock setting on low and high needles, loosened gas tank cap, pulled a couple times and had a pop (no choke), set idle little higher couple more pulls and pops, turn idle up more and it started and died turned up little more and it started,
ran in street for 5-10 minutes making few carb adjustments running Good, put it on the bench noticed very black oil/fuel on rear of chassie.
its is still first gallon of fuel going thru it,
Running 25:1 mix, Red Line oil 92 octane
