- Thread starter
- #21
makes enough sense. and there is no easier way to do this? I did not understand in your post .. by the way, how do you measure engine temperature?HPI is great but no matter what brand, the servos they come with aren't very good. But I'd first see how you like it, then upgrade the servos. The reason why a gas tank vent is a great thing is because, with a Baja, sometimes after a little while like 10-15 maybe more minutes, the engine Will shut off because you will loose fuel because there is too much pressure in the tank and you will have to remove the fuel cap, and re prime then engine bthen restart it, it's kind of annoying, but with a vent, it will that pressure and your engine will continue to run
