Project “UPTONOTHING” 5ive-B build
Well... my spare fit! So that issue is resolved...
Next question is... how to properly hook up the duel steering servo setup..
couldn't you just use a Y splitter from both servos to the reciever??
I don’t see why not honestly.. but I’ not sure if that’s the correct way or not.. which is why I asked lol don’t wanna mess anything up right outta the gate...
Put second servo in aux and slave it to the sreering(y)
I only have a 3 channel receiver... ?... and 3rd channel I’m gonna use for the kill switch
Also... what goes here?
transponder most likely
Ok so I haven’t forgotten anything lol
Since I only have one channel available for steering I’m gonna hook it up as follows...
Step 1- install splitter
Step 2- remove linkage
Step 3- power everything up.. zero everything out..
Step 4- reinstall linkage.. and adjust so that both arms slide on easily so they aren’t fighting each other..
Job done!
On paper.. that sounds like it should work ??
Getting the engine ready to drop in this morning...
Has anyone else ran into this little issue?
Guess I can always drill a new hole and make a spacer... ?
Ooooo nice you putting in a red arrow motor :love:(y)
Yes sir! It’s a 34 revolver super pro mod I believe he called it... ?
Got one more tank at 3/4 throttle and break in will be complete on this motor.. I stuck it on my 2.0 for a bit to see how it ran.. definitely has plenty of power even at this early stage.. way more than the engine I modified myself.. of course this one is 34cc not 32... which I know in itself makes a difference
