5IVE T Suspension Adjustment Questions
josegarcia8578
San Diego, CA
All,
I noticed that my rear wheel are rubbing on the rear fenders. I see the back of the truck sag during acceleration, whuxi I believe is causing the rubbing. How can I adjust the suspension to compensate? This is my first time adjusting a susnpenion.
Would I need heavier fluids in the back shocks? Or stronger springs? Or do I adjust the collars?
Overall, can you guys give me examples of what shock oil vs spring changes would do to the supension?
Thanks in advanced!
All,
Thanks in advanced!
You can first try adjusting the collars but know that the more you adjust it the more bouncy it will get, so try and see if doing that gives you a good ride (not too bouncy), if you try heavier springs, I believe changing the oils will only change rebound but I could be Incorrect (someone correct me if I'm wrong)
All,
Thanks in advanced!
51896these are the rear hing pin braces and the little black insets change toe and anti squat
if you change the anti squat in the rear to 3 degrees it will raise the back suspension(y)
i just change mine from 2 to 3 and it makes a big difference (y)
It seems like it does!
You think the 3 degree antisquat would help? I wasnt aware that was a tuning option.
I was thinking about changing the 'antisquat' by changing springs or fluids
What do you mean? What do you consider the whole toe plate?
The kit says it fits the 2.0
The kit does bolt right on the 2.0... but... For the 2.0 the toe plates aren’t adjustable themselves
If you remove the 2 bolts that hold them on and you remove the outer plastic piece you’ll see the toe plate which will be marked what degree it is... to change it you must buy a different set.. DDM sells em in different degrees..
The 5ive B comes with adjustable toe plates... as the pic Doug uploaded shows has different inserts to change toes settings... a much better setup IMO
thats a pic of the 5t rear......@Cupton79 is right cant change it with out buying in the tlr part?
Dag-nabbit! You tree’d me Doug! ???
Got it guys. The current set up does not allow for inserts. I would have to buy the tlr kit which would allow for the inserts. That's what I understood. I wonder why they didnt include that kit in the stock config? Haha
Adding to what's been said, thickening the centre diff oil will reduce power transfer to the front, reducing that squat in the rear. Don't thicken it too much though or it will kick the rear end out too easily when turning.
