Finally, the Vekta build will be done
Can someone confirm that the bottom linkage rod should slide freely through those 2 plastic retaining guide clips?
When I pull trigger for throttle and let it return to neutral it’s ok.....as soon as brake is applied=fine, let it go to return to neutral the engine goes full throttle.....the clips aren’t binding against anything but rod seems not to slide through easily when I release the trigger to return to neutral......and if all I described is correct, is the fix as easy as adding a little lube somehow?
50972
The stop on the left shouldn't be resting against your throttle linkage . Something on your linkage isn't set up right
Lmao....then I realized The clip wasn’t fastened correctly....? duh .....many thanks for your help. ??
Sorry, this fix was for my 5b....the Kraken isn’t back yet.....but I gathered you recognized that anyway....lol
What’s the rule ? pics or else....lol
Glad I could help.
I see you have a modded rovan.....? ? I have one, so I may need your help again some time.?
OOOOO nice original HPI! Kinda rare to see reao hpi's nowadays
Thank you, I am lucky to have 1 each of the “better” models of 1/5 scale, Losi 5, Vekta, fg, and a rovan....I love them all ??
Soon it will arrive.....soon ?? I can hardly contain myself....?
HHMHMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM>???????????????????????????????????????????????????????????????????????????????????????????????????
