Speedloader
- 37
+1????For a basher like (I assume) you and me, I don't see the point especially for close to $300, and like Sean said, the standard ignition system works well. Instead I'd take that $300 and put it towards a new motor. You get get a good 7.9Hp OBR g340 long block piston port for smack on $300, just throw yer existing parts (clutch, ignition, intake system, fan shroud ect) on it and you got 8hp.
Yeah but I doubt it will take yer motor to 8hpThey do write that we can expect a power increase between 15% to 25%.
But if you already have a powerful engine and exhaust, i suppose its worth, if an increase of 15-25% for an engine that already pushes 7-8hp.Thats great but still $300 you could almost buy an ESP Race ported top end
And a vrc tuned pipe ? i know what id do? and these will give a much better hp kick??View attachment 52577
From where do you have experience with this ignition?It will NOT fit RCMK motors . And it will not fit the 38-45cc motors out there now as the coil post on cylinder are a little higher up and the TPS unit has a small window in gap adjustment. The coil has almost twice the spark output and running a plug gap of .100 is normal with these. There is about 1 1/2 degree timing bump built into coil mount and rotor key pocket. You MUST use plastic starter pawls only or risk stripping the tabs off fan. The spark plug wire that comes with kit is way short and needs to be replaced right off. The power increase is not BS and well worth the bolt on upgrade. DDM has both types, OFF ROAD and ON ROAD kits. there is also a coil mount that has even more timing built into it . when installed on a well modded motor these kits are great and let the motor sing. they kept the weight of the rotor just under stock flywheel weight so motors will idle smooth and not stumble on spoolup. Ultra lite flywheels /rotors setups can cause major tuning problems and weights should be kept close as possible to the factory fly weight.
But if you already own this, then......???Id still not buy it?? i take $300 and put it towards
This View attachment 52580
9.4 hp = $409 on sale right now??
If i buy i will buy from TPSwe have bought 2 of these kits from DDM this year alone, Just be warned that for some reason DDM sends out the first one they grab in shipping room and will send ya the on road kit. Check box numbers very close and NOT DDMs stock sticker before you get to far along, And by the way NO decals are in any of the boxes that are shipped here to the USA from UK
