FID Racing DH
Reading the Rules!
Dragon hammer voltz
DRAGON HAMMER VOLTZ (2X70KG SERVOS,8S ESC, 680KV MOTOR)
SPECIFICATIONS
Specification:
Wheelbase:620mm
Tire track:465mm
Max speed:90km/h (8S)
Main chassis: 5mm 6061-T6
Esc Power Rating 300A: 8S Lipo
The main chassis height: 120mm
Servo Steering Power : 140kg (2x 70kg servos)
Battery box size: 190x75mm
Mud Terrain Tyres: 230x85mm
VoltZ Main Chassis:
5mm Thick Milled Alloy Chassis 6061-T6
Dual Steering Servo Set-Up 2x 70kg servos (140kg Combined)
Independent Front Shock Absorbers
Large Capacity Shock Absorebers: 235mm Rear 185.5mm Front
7mm Thick Shock Shafts
Four Link Rear Trailing Arm Suspension System
Billet Alloy CNC Machined Rear Axle
Billet Alloy CNC Machined Trailing Arms
Billet Alloy Upper Four Link Ends With Rose Joint Ends
Billet Alloy Fourlink chassis mounts
Front/Middle/Rear Differentials, With Billet Alloy Diff Cases
Rear Mounted 74/120 Brushless Motor
8S 300A ESC & Brushless Motor System
High Capacity Battery Box (8S /12S Lipo Battery Capability)
Voltz Electrical System :
ZTW 300A ESC,
Motor:680KV 34000 Max RPM,74/120 Brushless motor
8S Lipo Battery Capability
Built in Cooling System
ESC fixing plate(3MM) :reserve insert position for hobbywing 200A ESC
Dragon hammer Voltz 4WD drive System
Internal rear drive shafts,12mm
Helical cut front & rear differential crown & pinion gears
Rear Telescopic Centre CVD Driveshaft,25mm External
Front CVD Driveshaft,20mm external
Middle differential réversible System
Body shell
CLEAR, With 2 Full Livery Sticker Sheets
SPECIFICATIONS
Specification:
Wheelbase:620mm
Tire track:465mm
VoltZ Main Chassis:
ZTW 300A ESC,
Body shell
